‎12-24-2024 12:52 AM
Hi Team, I have imported a group from prod to dev instance. group was added in the dev, but group members were not added. Now, i have added the group members data manually and assign this group to workflow. when raising the REQ,
task is getting created, while assigning the group group member data is not reflecting. All users are in active state. Please help me to achieve group members data.
‎12-24-2024 12:55 AM
It's possibly because you created users manually and the sysIds are different when compared to PROD and DEV.
you should have migrated the users i.e. the group members via XML from prod to dev and then you should add them in correct group manually
OR
you can move those users via XML from prod to dev and then export and import sys_user_grmember records as well for these groups
‎12-24-2024 01:29 AM
Hi @raginiv ,
Check the reference qualifier of the user field, there might be different logic written.
‎12-24-2024 01:57 AM
please share the reference qualifier on assignment_group field on sc_task
Please check if other users are active and not locked out
‎12-24-2024 01:46 AM
what's the reference qualifier on that assigned to field?
ideally it should show the correct group members
Are you sure you added the correct users in correct groups?
Hi @raginiv ,
‎12-24-2024 04:15 AM
Hi @raginiv ,
This is what i had highlighted you to check.
Glad that your issue has been resolved.
The community now supports multi-solution acceptance, allowing you to accept multiple answers.
‎12-24-2024 04:26 AM
Hi @Runjay Patel , Thanks for your highlighting. you mentioned it as user field. so, i thought to check on User, not on assignment group. my bad, i didn't understand properly. If you highlighted and mentioned it as assignment group, it could be better to understand a fresher like me. Thanks for the solution. now i got your point. Accepted your solution too. many thanks to your response.
‎12-24-2024 01:52 AM
The group is assigned to particular service catalog. There are 8 members in the group, but while creating the SC task for a catalog item, assignment group is showing correctly, but in assigned to field only one user is reflecting .
