‎12-24-2024 12:52 AM
Hi Team, I have imported a group from prod to dev instance. group was added in the dev, but group members were not added. Now, i have added the group members data manually and assign this group to workflow. when raising the REQ,
task is getting created, while assigning the group group member data is not reflecting. All users are in active state. Please help me to achieve group members data.
‎12-24-2024 12:55 AM
It's possibly because you created users manually and the sysIds are different when compared to PROD and DEV.
you should have migrated the users i.e. the group members via XML from prod to dev and then you should add them in correct group manually
OR
you can move those users via XML from prod to dev and then export and import sys_user_grmember records as well for these groups
‎12-24-2024 01:29 AM
Hi @raginiv ,
Check the reference qualifier of the user field, there might be different logic written.
‎12-24-2024 01:57 AM
please share the reference qualifier on assignment_group field on sc_task
Please check if other users are active and not locked out
‎12-24-2024 03:54 AM
@Ankur Bawiskar Thanks for the support. Reference qualifier for the assignment group is Role ITIL. Role is not defined for the user. I have added the ITIL Role to the users and checked. now , it is working fine. Thanks a lot. Marking it as accepted solution.🙂
‎01-26-2026 03:41 PM
This usually means one (or more) of these problems exist:
The users referenced in group membership are not the same sys_ids as expected
The group membership records exist, but roles or visibility conditions prevent assignment
The workflow / assignment logic is caching or using a stale group reference
The users lack required roles (itil, catalog, etc.)
The group membership table is incomplete or inactive
Domain separation / ACL issue (if applicable)
Do This First
Check sys_user_grmember
Verify users exist & are active
Ensure users have itil
Re-publish workflow
Test manual assignment
Re-import group members properly
If my response has resolved your query, please consider giving it a thumbs up ‌‌ and marking it as the correct answer‌‌!
Nayan Patel
IT ServiceNow Consult, ServiceNow ArchX
If my response has resolved your query, please mark it Helpful by giving it a thumbs up and Accept the Solution
