Auto Insert of Required Approvers based on Affected CI Change Approval Group
sudhakar8
Change would like 'Required Approvals' to be added to a CMR automatically, based on the 'Change Approval Group' attribute on a CI (CI criteria: it is not Non-Operational) this would include CIs that are added to both the primary affected CI variable or or those included as part of the Affected CI TAB).
This is to be applied for both change types:  Normal and Emergency (i.e NOT to Standard changes)
//Add technical approvers to the change request when a new affected CI has been added.
var gr = new GlideRecord('change_request');
gr.addQuery('sys_id', current.task);
if(gr.next())
var change_grp = gr.u_technical_approvers_group.toString();
if (change_grp.indexOf(current.ci_item.u_change_approval_group) < 0)
gr.u_technical_approvers_group = change_grp + ',' + current.ci_item.u_change_approval_group;
//Force update to make sure the business rule to calculate risk and the change type will run when new affected CI has been added regardless the CR has
been updated with new approvals.
gr.setForceUpdate(true);
gr.update();
})(current, previous);
37 REPLIES 37
sudhakar8
Yes, i have added gs.info also
sudhakar8
sudhakar8
It is returning false
I tried in my personal dev.it is wrkg fine
if(gr.next())
var change_grp = gr.u_group.toString();
if (change_grp.indexOf(current.ci_item.u_change_group) < 0)
gr.u_group = change_grp + ',' + current.ci_item.u_change_group;
gs.log("group"+gr.u_group);
gr.update();
sudhakar8
Are I need to change current.task
