Auto Insert of Required Approvers based on Affected CI Change Approval Group
sudhakar8
Change would like 'Required Approvals' to be added to a CMR automatically, based on the 'Change Approval Group' attribute on a CI (CI criteria: it is not Non-Operational) this would include CIs that are added to both the primary affected CI variable or or those included as part of the Affected CI TAB).
This is to be applied for both change types:  Normal and Emergency (i.e NOT to Standard changes)
//Add technical approvers to the change request when a new affected CI has been added.
var gr = new GlideRecord('change_request');
gr.addQuery('sys_id', current.task);
if(gr.next())
var change_grp = gr.u_technical_approvers_group.toString();
if (change_grp.indexOf(current.ci_item.u_change_approval_group) < 0)
gr.u_technical_approvers_group = change_grp + ',' + current.ci_item.u_change_approval_group;
//Force update to make sure the business rule to calculate risk and the change type will run when new affected CI has been added regardless the CR has
been updated with new approvals.
gr.setForceUpdate(true);
gr.update();
})(current, previous);
37 REPLIES 37
your welcome. 🙂
sudhakar8
Hi Harish,
Do you have any idea about Blackout windows in Change management?
Thanks ,
Sudhaka V.
Twinkle5
Kilo Explorer
I received a change approval workflow but I am not sure how they added this -
Any suggestions please?
