04-05-2017 09:00 AM
Hello Experts,
I have created auto numbering for existing software model table. The issue is we have few old records for which we need numbering as well but it works only for newly created records. Is there a way to generate numbering for existing records as well. Thank you in advance.
Thanks & Regards,
Jag.
Enterprise Asset Management
04-05-2017 11:49 AM
Sorry change line 6 to gr.u_number so...
var gr = new GlideRecord("cmdb_software_product_model");
gr.orderBy('sys_created_on');
while (gr.next()) {
var nm = new NumberManager('cmdb_software_product_model');
gr.u_number = nm.getNextObjNumberPadded();
gr.autoSysFields(false); // Do not update sys_updated_on, sys_updated_by, and sys_mod_count
gr.setWorkflow(false); // Do not run any other business rules
gr.update();
04-05-2017 10:16 AM
I have 825 records in total.
Jag.
04-05-2017 10:22 AM
Ok, My logic is based on your total count
var prefix = "SW";
var zero = "0000";
var counter = 0;
var gr = new GlideRecord('cmdb_software_product_model');
while(gr.next() && counter<825){
counter += 1;
gr.u_number = prefix+zero+counter;
gr.update();
Please check it
Please Hit like, Helpful or Correct depending on the impact of the response
04-05-2017 10:27 AM
Hi Alikutty,
Number is still showing empty. It did not work.
Jag.
04-05-2017 10:34 AM
Let me try it out, I will get back in some time.
04-05-2017 10:35 AM
Sure. Thank you for your help.
