04-05-2017 09:00 AM
Hello Experts,
I have created auto numbering for existing software model table. The issue is we have few old records for which we need numbering as well but it works only for newly created records. Is there a way to generate numbering for existing records as well. Thank you in advance.
Thanks & Regards,
Jag.
Enterprise Asset Management
04-05-2017 11:49 AM
Sorry change line 6 to gr.u_number so...
var gr = new GlideRecord("cmdb_software_product_model");
gr.orderBy('sys_created_on');
while (gr.next()) {
var nm = new NumberManager('cmdb_software_product_model');
gr.u_number = nm.getNextObjNumberPadded();
gr.autoSysFields(false); // Do not update sys_updated_on, sys_updated_by, and sys_mod_count
gr.setWorkflow(false); // Do not run any other business rules
gr.update();
04-10-2017 10:39 AM
Can you check if you have written any business rule (on before) to abort update on that table? (setAbortAction)
Please Hit like, Helpful or Correct depending on the impact of the response
04-10-2017 10:48 AM
Yes there are few Business rules with Abort action. I disabled all of them and tried the script but still it did not update the record with numbers.
Jag.
04-10-2017 10:55 AM
Are you able to update number manually on a record?
04-10-2017 12:04 PM
Hello Alikutty,
I am able to update the record manually.
Jag.
04-10-2017 12:09 PM
Try to write an on after business rule on the table and execute the code by forcing an update on record with a value change.
