Avoid attachments less than 10kb to get attached to incidents received via reply email to servicenow
Debasis Pati
Hello Everyone,
When servicenow receives emails as reply we have a inbound email action it by default oob attaches the attachments to the target incident/record .
Now we wanted to avoid less than 10kb files to get attached to the target record.
for images to avoid less than 10kb we have oob property "glide.email.inbound.image_sys_attachment.filter.minimum_bytes" but what about other file types how we can avoid that what ever attachments are coming in emails?
@Ankur Bawiskar any suggestions?
Debasis
@Debasis Pati
yes you can try to use that
Did the approach I shared using BR on sys_journal_field work for you?
21 REPLIES 21
@Debasis Pati
the OOTB Reply type Inbound action on incident won't copy the attachments to target record
So you can write script in there
Hello @Ankur Bawiskar ,
i dis see this also even it is not copying there are no script here for that i could see it's getting copied to the target record also i have modified the script and tried but no luck
also i feel we can write script in "sys_email_attachment" table to achieve this correct me if i am wrong.
@Debasis Pati
Hope you are doing good.
Hey @Ankur Bawiskar ,
i tried the inbound email action to not to copy even with tat script to copy attachment or not it always copies .
@Debasis Pati
are you not able to copy the attachments from email record to target?
once you are able to do that, then you can handle deletion logic
