Best way to use approval group script for multiple approvers.
booher04
I am trying to set up a group approval that only marks the request "Approved"   when 3 of the 4 members approve, we do not want it waiting for all 4, just until the first 3 that approve.   We do not have different groups, all of the approvers are in the same group.   I assume this needs to be done with the "Wait for: Condition based on script" approach.   Does anyone have any ideas on this or a better way to do it?   What we currently have in there is this:
var id,
        count = 0;
for (id in groups) {
        count += groups["bc1b9479db590700ee2df456bf9619cf"].approved;   // Sums the total number of users who have approved from each group
if (count == 3) {
        answer = 'approved';   // Approve if 3 users from any group have approved
else if (counts.requested == 0) {
        answer = 'rejected';   // Reject if less than 3 users approved and no groups are still pending approval
Pradeep Sharma
Hello Jeffrey,
You may find the below blog helpful.
https://www.servicenowguru.com/graphical-workflow/approval-percentage/
nitin_kumar
Mega Guru
Hi Jeffery,
I have used the following script to achieve something similar
var approvePercent = 50;
if((counts.approved/counts.total)*100 >= approvePercent){
if((counts.rejected/counts.total)*100 > (100 - approvePercent)){
Nitin.
PS: Hit like, Helpful or Correct depending on the impact of the response
if rejetced i need to remove the records from the related list.
kindly advise
iamright
Giga Contributor
I used this for a percentage of approvers in the approval workflow.
I have 6 approvers.  I only 3....
if (counts.approved/counts.total > .49) {
else if (counts.rejected/counts.total > .10) {
