‎10-26-2012 03:36 AM
Can we redirect to any other page or homepage using client script.
I need that if the IF condition true then redirect to homepage.Please help me out
Change Management
‎04-17-2019 12:44 PM
I know this post is old and Harsh might have got his answer but just in case someone stumbles upon this post and looking for a way to redirect using client script then below code snippet might help:
if (newValue == 'expense_freight_realestate'){
var redirectURL = 'https://www.google.com/'; //url to redirect; this approach works in platform and Service Portal view
top.window.location = redirectURL ;
Please note that in case you want to open up external link within the main ServiceNow Frame then you may use g_navigation.open() but this approach doesnt work when the Service Catalog/form will be used in Service Portal.
‎02-05-2018 10:50 PM
Indeed, our dev teams have protected the necessary JavaScript classes and they are not accessible anymore.
You will need to work with location.assign as mentioned by Pratul.
I might be an idea to raise an Enhancement request via HI. Our PM's are listening and could surely put this on the backlog if enough interest exists.
‎09-08-2015 10:34 AM
Hi Mark.
Using
location.assign("https://www.google.com");
It is redirecting me to a blank page rather than the actual destination.
Pratul Agarwal
‎01-12-2017 03:34 AM
You can write a script in UI page directly to redirect.
like
<script>
window.location.href = "URL";
</sccript>
‎04-23-2020 11:41 AM
You saved my day with this! Thanks!!
