catalog item variables not showing in catalog task
somujit
Hello People,
We have added a catalog item using the ItemDesigner and then added some variables using the Maintain Items.
When i open the item from the maintain items, i see the "Item Designer Workflow" in the Workflow field as read-only.
The Variables defined as below
The RITM generated upon placing the order request is as below, to which a task gets auto generated -
Upon viewing the created Task, the variables value i.e. test for the field abc defined while ordering the catalog item isn't showing in the task form
Any suggestions, how we can bring in the Variable values in the Task form as it appears in the RITM would be much appreciated..!!? TIA..
~Somujit
16 REPLIES 16
Thanks for the response, it is global, I think the item designer module is a dud, I'll use other methods to create cat items.
Thanks, Dan. Forgot about this one and your post saved me some time.
