Change management
Community Alums
Options
11-12-2023 11:37 PM - edited 11-13-2023 02:59 AM
if all tasks are open change should not move to review. I tried a BR with code it is updating the closed task to canceled, It is not updating the open tasks to cancel. Can anyone help me on this.
Options
11-13-2023 01:52 AM
HI @Community Alums
Can you give me example. Bcz in this case, at first point you should not create multiple task , first you are creating and then you are cancelling which is adding record and operation on data base.
