create change task using Business rule
Priyanka Mathur
Hi ServiceNow Experts,
My requirement is to create a change task, when the change request short description contains "Planned Outage". I have written the below script. Can you please help me with this, as change task is not being triggered.
createTask();
function createTask() {
var org = current.u_organization;
var groupName = '';
if (org == 'IT') {
groupName = 'IT-Network Operations';
var cTask = new GlideRecord('change_task');
cTask.initialize();
cTask.short_description = 'Change task should have test and verify';
// cTask.description = '';
cTask.parent = current.sys_id;
cTask.change_request = current.sys_id;
cTask.cmdb_ci = current.cmdb_ci;
cTask.u_predecessor = 'No';
cTask.assignment_group.setDisplayValue(groupName);
Murthy Ch
@Priyanka Mathur
Can you try this:
createTask();
var groupName = '';
if (org == 'IT') {
cTask.initialize();
cTask.insert();
Murthy
You will use an after business rule, please follow the steps :
    createTask();
       var org = current.u_organization; // if u_organisation is a string field
        var groupName = '';
        if (org == 'IT') {
            groupName = 'Service Desk'; // please put the name of your group
            cTask.initialize();
	    cTask.insert();
})(current, previous);
Hajar
