‎07-08-2022 06:35 AM
Hi community members,
I want to create an incident with script I was able to achieve it but I want to pick a record producer and create incident using script. is it possible to create an incident by pulling a record producer into script and create an incident.
please help.
Thanks.
‎07-08-2022 07:14 AM
Are you saying you wish to submit record producer from script so that incident gets created?
If yes then check this link
How to Trigger change workflow/record producer from transform script
‎07-08-2022 06:49 AM
Could you please provide more info on what you're trying to accomplish?
At the end of the day, a record producer is nothing more than a script running on a table to create a record based on that defined script, so you should be able to achieve your desired incident creation logic without invoking the record producer, just by simply replicating whatever the record producer's script is doing.
If this answer is helpful please mark correct and helpful!
Christopher Perry
Chris Perry
‎07-08-2022 06:56 AM
Hi there!
Can you share what you did so far to achieve above requirement and also explain it some more.
Palak
