Creating Problem from an Incident
Steven Chaparro
Hello All,
Im trying to complete the ITSM (Madrid) Simulator but now I am not sure if the simulator has some issues or I don't know what are the best practices.
One of the task is creating a Problem from an Incident. The instructions are the following:
We want to be able to create a new problem from an incident with all necessary information.
1. Following fields should be copied from an incident when a new problem is created from an incident.
- Configuration item
- Priority
- Assignment group
- Short Description
- Description
2. Impersonate itil.<your first name> and click to create a new problem from an incident. Following fields should be copied from an incident:
- Priority
- Assignment group
- Short Description
- Description
A quick search in the servicenow documentation I found this: Create a problem | ServiceNow Docs
With the following note in the procedure to create a problem from an incident:
Note: Use the property List of attributes (comma-separated) that will be copied from the incident to create a new problem (com.snc.problem.create_from_incident.attributes) to specify fields on the Incident form. The values of these fields are copied to the respective fields on the Problem form.
A screenshot where I added the fields required...
So I did that, and still the task failed, with the following recommendation:
"Please validate fields are copied from Incident to Problem using best practices."
What I am missing here?
Adding the field inside the property is an best approach for simulator !!
If you hard code a script it in the UI action then the task will fail
Please mark the answer as correct or helpful, if it helped you !!!
Chalan
16 REPLIES 16
I added the field inside of the property, I didn’t hard-coded the UI script, but the task is still failing.
hvrdhn88
Giga Patron
just for testing can you open the background script and copy the one incident sysid , here you will test if that script include is working or not.
Background script
var current = new GlideRecord('incident');
current.get('Mention the sys_id of that incident here');
new IncidentUtils().getProblemFromIncident(current);
Now Run it and see if it is creating a problem with those field value or not.
Ok will do, but I will like to add that in the instance it is creating a problem with all the fields without any issue, is the simulator task that is not being validated.
here is the UI action on my instance, and I added the field that needed to be copied but still the task failed.
I will let you know the result from the background script but I expect the script include to be working with no issue.
Interesting, the background script didn’t worked, but the UI action is working. here’s a screenshot with all the fields being copied from the incident:
my bad, i missed insert() in the script.
var ab = new IncidentUtils().getProblemFromIncident(current);
ab.insert();
anyway, is it working now? if your query has resolve, kindly mark the answer correct and close thread.
