CSAT Survey not triggering properly
‎01-17-2022 03:18 AM
Dear Experts,
I've implemented the CSAT for incident. The CSAT is triggering with the help of 'asmt_assessment_instance'. I've configured as when incident is Closed it should trigger the CSAT notification. The configuration is done in 'asmt_metric_type' table.But when incident is Closed state it's not sending to 'asmt_assessment_instance' table.
Can you please clarify when 'asmt_assessment_instance' table gets a record creation and where I should check the configuration. Please advice.
Note: I tested the config in asmt_metric_type table. Based on the configuration it creates a new business rules.
Config Checks: The mentioned below checked and configured properly.
1. Enable the trigger condition in asmt_condition with the help of asmt_metric_type.
2. Survey should be 'Published' state.
3. Provide public access for the survey in asmt_metric_type
4. Enable 'Send Notification' as true in asmt_metric_type
Suresh.
‎01-17-2022 07:04 AM
Hi Suresh,
Since the Survey is trigged from Notification. Can you also check the Incident survey notification?
When to send condition is perfect.
Under What will it contain, check the script used are correct.
Sunny Khandelwal
‎01-17-2022 07:11 AM
Hi Sunny,
Please find below email script used in notification template and script called in href link
The record not created in asmt_assessment_instance table when the incident is closed state. Due to the reason - mail_script:asmtInstanceID shows an empty. Because of the reason, survey not listed to the end user.
self_service?id=take_survey&instance_id=${mail_script:asmtInstanceID}
Suresh.
‎01-17-2022 07:23 AM
Hi Suresh,
Can you try the below code:
(function runMailScript(/* GlideRecord */ current, /* TemplatePrinter */ template,
/* Optional EmailOutbound */ email, /* Optional GlideRecord */ email_action,
/* Optional GlideRecord */ event) {
var assesGR = new GlideRecord("asmt_assessment_instance");
assesGR.addQuery("user", current.caller_id);
assesGR.addQuery("trigger_table", current.getTableName());
assesGR.addQuery("trigger_id", current.sys_id.toString());
assesGR.setLimit(1);
assesGR.query();
if (assesGR.next()) {
link = new AssessmentUtils().getAssessmentInstanceURL(assesGR.sys_id.toString());
var url = '<a href="' +link + '">' + 'Please click here to take Survey' + '</a>';
template.print(url);
//var link = gs.getProperty('glide.servlet.uri') + 'sp?id=take_survey&type_id=' + '75df84fd1bbae410aed455352a4bcbed';
})(current, template, email, email_action, event);
Sunny Khandelwal
‎01-17-2022 08:05 AM
Hi Sunny,
Thanks for the update. The mentioned script shows once record created in asmt_assessment_instance table. but here the issue is the record not created in 'asmt_assessment_instance'. if this issue not resolved the mentioned script wont help to get the link in survey notification.
Please correct my understanding.
Suresh.
‎01-17-2022 09:28 AM
Hi Suresh,
Once the incident is closed, then a new record is created in "asmt_assessment_instance" table automatially.
Open any incident. Change the state to "CLosed".
Got the the table & check new entry for the same.
Sunny
