CSAT Survey not triggering properly
ersureshbe
Dear Experts,
I've implemented the CSAT for incident. The CSAT is triggering with the help of 'asmt_assessment_instance'. I've configured as when incident is Closed it should trigger the CSAT notification. The configuration is done in 'asmt_metric_type' table.But when incident is Closed state it's not sending to 'asmt_assessment_instance' table.
Can you please clarify when 'asmt_assessment_instance' table gets a record creation and where I should check the configuration. Please advice.
Note: I tested the config in asmt_metric_type table. Based on the configuration it creates a new business rules.
Config Checks: The mentioned below checked and configured properly.
1. Enable the trigger condition in asmt_condition with the help of asmt_metric_type.
2. Survey should be 'Published' state.
3. Provide public access for the survey in asmt_metric_type
4. Enable 'Send Notification' as true in asmt_metric_type
Suresh.
11 REPLIES 11
ersureshbe
Thanks for everyone input. I sorted the issue. Solution - In trigger condition, the repeat interval shows as 30 days. i.e., once notification triggered it should wait 30 days.
If change the repeat interval as 0 then it's working fine.
Thanks all.
Suresh.
Good to hear Suresh.
If my response helps you please mark them helpful.
Sunny Khandelwal
