current.setAbortAction(true) doesn't work if nothing is changed to the incident record
natecousins
I have a "before" Business Rule to prevent an update to an incident record if the 'Assigned to' user is not a member of the 'Assignment Group'. The BR only runs on 'Update', but only seems to work if you modify the record like change the value of a field. If you do not make any changes, the BR will not work.
I have set the Order field to 1 and to the low number like 10,000. Still doesn't work. I have added current.setWorkflow(false), and it still doesn't work.
The conditions are: assigned_to is not empty AND assignment_group is not empty
CODE:
// Add your code here
var assigned_to = current.assigned_to;
var assignment_group_display = current.assignment_group.getDisplayValue().trim();
var assigned_to_display = current.assigned_to.getDisplayValue().trim();
var userObj = '';
userObj = gs.getUser().getUserByID(assigned_to);
if (!userObj.isMemberOf(assignment_group_display)) {
var msg = gs.getMessage('ERROR: ' + assigned_to_display + ' is not a member of ' + assignment_group_display + '. Please ensure the "assigned to" user is a member of the "assignment group".');
current.setAbortAction(true);
current.setWorkflow(false);
gs.addErrorMessage(msg);
})(current, previous);
Any thoughts why?
21 REPLIES 21
Thanks, but this did not work either. Remember, I'm trying to test the rule on an existing incident record where the assigned_to user is not a member of the assignment group. In my test, I'm not changing or modifying any fields. I'm simply clicking 'Save'. It proceeds without giving me an error message. However, if I change any value of any field, then it will give me an error.
Is this expected behavior?
If you are not making any change than business rule will not run since there is no change.
Thanks. I'm okay if this is expected behavior. If it is, is there any way to get it to work without changing any value of the incident record?
Rahul Shandily3
Giga Guru
Hey natecousins,
Try this and it will work for you.
Remove the codition assigned_to is not empty.
Best Regards,
Rahul
Please mark this as COrrect / Helpful if it resolved your query.
Thanks, but this did not work.
