Data load and transform map through Catalog Item
varma2
I need to import data load and transform map through catalog item. When ever user submit a request with attachment the data should load  through transform map via ritm only.
Please suggest how it possible.
Hari
Ankur Bawiskar
I have written article for same
Refer that and do the steps mentioned in that.
Please mark it helpful as well
Data load and transform via Catalog Item
Just one thing to remember if you are doing your catalog item in scoped application then you should allow Can Delete access
15 REPLIES 15
you should use field map script and search for the correct manufacturer based on domain name from excel.
Also for updating the dynamic user name this you can try. Not sure how much it works
1) on onAfter transform script query sc_req_item table and pick the latest RITM
2) get the RITM -> Request -> Requested For and update as this
(function runTransformScript(source, map, log, target /*undefined onStart*/ ) {
	// Add your code here
var ritm = new GlideRecord('sc_req_item');
ritm.orderByDesc('sys_created_on');
ritm.addQuery('cat_item.name', 'Your Catalog Item Name Here');
ritm.setLimit(1);
ritm.query();
if(ritm.next()){
target.sys_created_by = ritm.request.requested_for.user_name;
target.update();
})(source, map, log, target);
Hi Ankur,
 Above script, I need to give in runscript  or in the business rule.
Varma
in the onAfter transform map script
I could see you had marked my response as correct earlier and now it is not.
If I was able to help you for your original question please mark my response correct and helpful.
Hi Ankur
can you tell the same things in flow designer except for workflow?
