Default work note
inatherese
Kilo Expert
I want the "work notes" - field to be the default view when viewing a ticket (instead of the "Additional Comments"- field showing), so it will look like this:
I found a record in the dictionary called "Work notes" on the task table, and tried setting this to default value "true". Then I get the desired result when viewing a ticket, but not when creating a new one. It then shows both the "Additional Comments" and the "Work notes"-field, and it says "true" in the "Work Notes"-field. I belive the original behavior is both of the fields showing like this, but of course not showing the "true" statement in the "Work notes"-field.
Anyone got an idea as to how I can default show the "work notes" (work notes = ticked) instead of the additional comments? It would be OK for both fields showing on a new ticket as well, but I would not want to see "true" in the work notes - field.
Thanks in advance!
Hi Ina,
Look what I found... Two user preferences that do what you want... you can make these a single field or expand them to show both. You can default to work notes too!
I just changed mine on incident and noted the changes in sys_user_preferences. If you want make those the default for people, just remove the user name and change the System field to true (checked) and insert&save the new record. It doesn't prevent people from changing it to the way they want (collapsed and comments first), but it gives you a default for noobs.
Let me know if you need more help or if that answers your question.
39 REPLIES 39
I'm referring to the ability to set the system preference to display the internal "work notes" journal opposed to the public "comments" in task and incident. I have included a screen shot to jog your memory.
You don't set the preference to checked or unchecked, you set the glide.ui.incident.stream_input to the name of the field you want it to default to. It defaults to comments, I changed it to work_notes in the image above.
Got it, thanks. Is there any way to code that so that it cannot be changed?
You could try an ACL on the sys_user_preference table specific to that particular setting. Use a condition field for easy maintenance.
Example: Enable write access to that table/fields
Name | is not | glide.ui.incdient.stream_input
Docs: Access control rules
Docs: Contextual security
Security Best Practices - ServiceNow Wiki
OK... I'm against a wall here. I have tried all manner of ACL with this, including your suggestion, and still the ACME Itil user is able to write a preference. I have included the 3 ACLs that I have in place for the table which includes the glide name for task, incident and the ability to show both work_notes and comments at the same time. Can you think of any reason why ACME Itil should be able to write to this record? I have verified the user does not have the 'admin' role. Thank you so much for your help!
