Default work note
inatherese
Kilo Expert
I want the "work notes" - field to be the default view when viewing a ticket (instead of the "Additional Comments"- field showing), so it will look like this:
I found a record in the dictionary called "Work notes" on the task table, and tried setting this to default value "true". Then I get the desired result when viewing a ticket, but not when creating a new one. It then shows both the "Additional Comments" and the "Work notes"-field, and it says "true" in the "Work Notes"-field. I belive the original behavior is both of the fields showing like this, but of course not showing the "true" statement in the "Work notes"-field.
Anyone got an idea as to how I can default show the "work notes" (work notes = ticked) instead of the additional comments? It would be OK for both fields showing on a new ticket as well, but I would not want to see "true" in the work notes - field.
Thanks in advance!
Hi Ina,
Look what I found... Two user preferences that do what you want... you can make these a single field or expand them to show both. You can default to work notes too!
I just changed mine on incident and noted the changes in sys_user_preferences. If you want make those the default for people, just remove the user name and change the System field to true (checked) and insert&save the new record. It doesn't prevent people from changing it to the way they want (collapsed and comments first), but it gives you a default for noobs.
Let me know if you need more help or if that answers your question.
39 REPLIES 39
Andreas,
How are you testing this? As you said, I de-activated my BR for the sys_user_preference table, and have removed all but the system preferences for the 3 preferences I am trying to manipulate. Here is my test:
  • When I enter a record, I see the work_notes field displayed.
  • I change it to comments and enter a note
  • Select update on the record
Results
  • re-enter the record and the comments field is displayed
Hi Mike,
It did not work on my requested development instance on helsinki (patch4) but when I upgraded it to patch 7 it started to work as I explained.
I have implemented this solution to my company instance and it works fine there too.(Helsinki patch 5)
What version and patch are you on?
//Andreas
glide-helsinki-03-16-2016__patch4-08-10-2016
Chuck
All I want is making the fields both visible and allow control through UI policy. I would like not to use the 'check box' work notes that was introduced there as baseline. How to accomplish this?
Thank you
Hey is there any script for this default work notes, without doing manual, can I do scripting it self?, if there how can I do that?
