Difference between Asset and Configuration Item???
‎05-05-2016 06:41 AM
Want to Know the exact difference between Asset and Configuration Item.
- 54,319 Views
‎05-13-2016 10:07 PM
A Configuration item may BE an Asset, like a computer, software or server hardware. Something that needs to be tracked financially. Yet it is something that can be configured, something that requires a change.
An asset may NOT be a configuration item. It does need tracked financially. However it is something that can NOT be configured. (Toner, mouse, keyboards, etc)
‎10-06-2016 11:41 AM
Well! This just blew my confusion away. Thank You
‎10-18-2016 05:19 AM
In easiest way one can define the difference between asset and ci as
CI--> anything which must be configurable,not participate directly in any financial decision.Provides the strength of your organisation in terms of working items.
Asset: Anything which may or may not be configurable,but participate in all financial decision.
Let's take an example that can easily signify the similarity and differences:
1) Similarity:
Server - It is both an asset as well as a CI.
2) Difference:
Building - It is an asset but not a CI.(It is totally depend on financial aspect.)
Document - It is a CI but not an asset.(you can add/delete info i.e configure document,but document financial value doesn't appreciate/depreciate e.g like user manual..If it is SHARE MARKET DOCUMENT than it may be consider as ASSET+CI)
‎01-25-2017 01:16 AM
Thanks for your very useful input !
What would you use to manage spare parts (volume = thousands of) that are just coming in the company a few hours or a few days and then go away to help field technicians to repair a machine ?
Knowing you don't want to spend too much time to enter too much information about the spare parts (just the minimum like quantity, name, description, reference, location).
Kind regards,
Bernard
‎01-25-2017 04:56 AM
Hi Bernard,
Consumables (Consumables life cycle) are a great way to handle things like spare parts. Consumable records let you focus on quantity and location.
Ben
