Dynamic filter using script include as reference
tiagomacul
Tera Sage
I'm trying to create a Dynamic filter using script include or also Business Rules, how ever, I've been trying and when i tried to recognize how to do:
  1. Script include / Application: Global / Accessible from: All application scopes
  2. Dynamic Filter / script: javascript: new <includename>.<function name>(); / Reference Script: Script Include: <includename>
Script Include
var appLogin = Class.create();
appLogin.prototype = Object.extendsObject(AbstractAjaxProcessor, {
filterMe: function(){
var vuserid = gs.getUserID();
vReturn = "";
      vIsTrue = this.isTrue();
if (vIsTrue== false)
vReturn = vuserid;}
else
vReturn = this.GetMyBoss();
return vReturn;
isTrue: function(){
var ObjUser = new GlideRecord('sys_user');
ObjUser.get(vuserid);
var vistrue= ObjUser.u_istrue;
return vistrue;
GetMyBoss: function(){
var vmyboss= ObjUser.u_myboss;
return vmyboss;
type: 'appLogin'
Dynamic FIlter Options
  • new x_appLogin().filterMe()
    • org.mozilla.javascript.EcmaError: "x_appLogin" is not defined.     Caused by error in <refname> at line 1==>     1: javascript: new x_appLogin().filterMe();
  • new x_appLogin.filterMe();
    • org.mozilla.javascript.EcmaError: "x_appLogin" is not defined.     Caused by error in Phase 2 Jelly: file:/glide/nodes/xxxxxxxxxxxxxxxx004_16033/webapps/glide/itil/WEB-INF/ui.jtemplates/doctype/template_bar.xml.2 at line 1==>     1: new x_appLogin().filterMe();
  • new appLogin.filterMe();
    • org.mozilla.javascript.EcmaError: undefined is not a function. Caused by error in <refname> at line 1 ==> 1: javascript: new appLogin.filterMe();
  • gs.include('appLogin'); filterMe();           OR         javascript:gs.include('appLogin'); filterMe();
    • org.mozilla.javascript.EcmaError: "filterMe" is not defined.     Caused by error in Phase 2 Jelly: file:/glide/nodes//4_16033/webapps/glide/itil/WEB-INF/ui.jtemplates/doctype/template_bar.xml.2 at line 1==>     1: gs.include('appLogin'); filterMe();
  • applogin.filterMe();
    • org.mozilla.javascript.EcmaError: "applogin" is not defined.     Caused by error in <refname> at line 1==>     1: applogin.filterMe();
  • javascript:applogin.filterMe();
    • org.mozilla.javascript.EcmaError: "applogin" is not defined.     Caused by error in Phase 2 Jelly: file:/glide/nodes16033/webapps/glide/itil/WEB-INF/ui.jtemplates/doctype/template_bar.xml.2 at line 1==>     1: javascript:applogin.filterMe();
BUT
Anything happens on my filter,
What am i making for isn't work?
Can you just try without javascript in your dynamic filter's script field (in your screen shot you are using javascript keyword), like,
new appLogin().filterMe();
OR
gs.include('appLogin');new appLogin().filterMe();
16 REPLIES 16
Deepak Ingale1
If you are in scoped App and trying to access a script include from global scope, you will have to provide the namespace
new global.scriptIncludeName() or new x_yourAppNameSpace.scriptIncludeName()
tiagomacul
Tera Sage
HI Guys,
It's working when:
function filterMe(){
          return "xxxxxxxxxxxxxxx";
and on Dynamic Filter
gs.include("appLogin"); filterMe();
But i discovered, isn't my real problem, i'm looking for some conversion data problem on Glide Query
var vsys_id = gs.getUserID();
var objU= new GlideRecord('sys_user');
                  objU.addQuery('sys_id', vsys_id );
                  objU.query();
                  objU.next();
Thank You
Please check if these changes helps,
1. if (vIsTrue == 'false') //Let's put false keyword under quotes
2. var vmyboss= ObjUser.u_myboss.toString(); //let's have toString() while returning the myBoss value in GetMyBoss function
