Dynamically pass values through to template fields
Jeff Krueger1
Is there a way to dynamically pass values through the template fields?   For instance, having a short description of "Create mainframe account for <requested_by>" which would pass the matching value through once the template is applied:
Thanks John, I haven't tried your code yet, but I did add a GlideRecord query which did the trick:
  gr.get(g_form.getValue('requested_by'));
  var rb = gr.name;
  if (newValue == 'New Mainframe Account') {
  g_form.setValue('short_description', newValue + ' for ' + rb);
Hey Jeff,
To answer your question about g_form.getValue giving you a sys_id - that's because you're getting a value of a reference field which always has the sys_id as the field value. It would be nice if something like g_form.getDisplayValue() would work, but that would only run server side and not in a client script such as yours.
I would recommend using the g_form.getReference() function with a callback that outputs the referenced user's title which is what you want.
Something like this in your code:
  var rb = g_form.getReference('requested_by', function(ref) {
        return ref.getValue('title');   //title is the field in the user table that shows the full name, but you can choose any field
I did not test that code, but let me know if that helps you out.
  var rb = gr.name;
