Email script is not working
Mahalakshmi Rav
When the current caller id email ends with "@gmailusa.com", I need to send the notification to "USA tower" additionally. I wrote the email notification script as mentioned below but it's not working.
(function runMailScript(current, template, email, email_action, event) {
    var gr = new GlideRecord("sys_user");
    if (gr.get(current.caller_id)) {
        var callerEmail = gr.getValue("email");
        if (callerEmail.endsWith("@gmailusa.com")) {
            email.addAddress("to", "usatower@gmail.com", "USA Tower");
})(current, template, email, email_action, event);
Shivalika
Hello @Mahalakshmi Rav
I don't think you can modify the "TO" for any email notification using email script, you can modify "CC" and "BCC".
I had also tried this sometime back, I don't think this works. Try changing it to "CC" and see once, if the mail script is correct - with all the fields correct - it will definitely work. Else you might need to debug script.
Kindly mark my answer as helpful and accept solution if it helped you in anyway. This will help me be recognized for the efforts and also move this questions from unsolved to solved bucket.
Shivalika
My LinkedIn - https://www.linkedin.com/in/shivalika-gupta-540346194
My youtube - https://youtube.com/playlist?list=PLsHuNzTdkE5Cn4PyS7HdV0Vg8JsfdgQlA&si=0WynLcOwNeEISQCY
Mahalakshmi Rav
Hello @Shivalika ,
My initial code was working when I replaced it with "cc". I wasn’t checking the copied section, instead I was checking in the recipient. Thanks for your suggestion!
I am glad it worked for you 🙂. May be you can try my script as well if that's working you can mark it also as solution.
Shivalika
