Event in Queue State not Processing
Toms V
Kilo Expert
I have a custom field "U_scheduled_date" in customer Service case table. I   need to create an event that needs to be fired before 3 minutes of the date time value in the custom field. I have created an event that is currently being queued but the event always stays in ready state and its not processing. Below is the code i used
var gr = new GlideRecord('sn_customerservice_case');
gr.addQuery('sys_id',current.sys_id);
if(gr.hasNext())
                while (gr.next())
                              var newdate=   current.u_scheduled_date.getDisplayValue();
                              var gdt = new GlideDateTime();
                              gdt.setValue(newdate);
                              gdt.addSeconds(-180);
                              gs.eventQueue("sn_customerservice.DOB_Update_Case_Sched", gr,   gs.getUserID(), gs.getUserName(),gdt);
Any idea whats the issue here is? Can any of you guys help please?
Tom
Hi Berny,
I didn't say this is a constraint. If you look at Toms post you will see that gs.eventQueue is under this form:
The function call is done with 5 parameters out of which last argument value is a date object rather than a queue name. In his screenshot you can see queue contains a date rather than either being empty or containing a specific queue.
Here:
https://developer.servicenow.com/app.do#!/training/article/app_store_learnv2_automatingapps_jakarta_...
Hope this clarifies your question.
19 REPLIES 19
Event Process are in Running state...yet to change to ready   state?
I can see the Event logs but..all are in Ready state     ....Notification is not triggering...
sowmyab
Giga Contributor
Is Process On field having same value as Created On?
Did n't get the question .
