Event in Queue State not Processing
Toms V
Kilo Expert
I have a custom field "U_scheduled_date" in customer Service case table. I   need to create an event that needs to be fired before 3 minutes of the date time value in the custom field. I have created an event that is currently being queued but the event always stays in ready state and its not processing. Below is the code i used
var gr = new GlideRecord('sn_customerservice_case');
gr.addQuery('sys_id',current.sys_id);
if(gr.hasNext())
                while (gr.next())
                              var newdate=   current.u_scheduled_date.getDisplayValue();
                              var gdt = new GlideDateTime();
                              gdt.setValue(newdate);
                              gdt.addSeconds(-180);
                              gs.eventQueue("sn_customerservice.DOB_Update_Case_Sched", gr,   gs.getUserID(), gs.getUserName(),gdt);
Any idea whats the issue here is? Can any of you guys help please?
Tom
Hi Berny,
I didn't say this is a constraint. If you look at Toms post you will see that gs.eventQueue is under this form:
The function call is done with 5 parameters out of which last argument value is a date object rather than a queue name. In his screenshot you can see queue contains a date rather than either being empty or containing a specific queue.
Here:
https://developer.servicenow.com/app.do#!/training/article/app_store_learnv2_automatingapps_jakarta_...
Hope this clarifies your question.
19 REPLIES 19
For events there is an extra field called "Process On". It usually contains same value as Created On field (same date/time). I am trying to understand if the process on is not in the future. See below example:
sowmyab
Giga Contributor
Yes it's same
Are these custom events? Have they been registered?
YEs its custom events..
So if they are custom events:
- are they registered?
- is there a script action to process them?
