Fields are not populating after submitting record producer
sinu2
HI Team,
I have a record producer. Inside record producer i have created a multi row variable set name calle d as "item_list". Inside multi row variable set i had 6 variables.
As soon as i submit the record producer from portal,  A record is creating to that table but fields are showing empty.
So how can i map those MRVS variable content inside native view table fields?
I had created a before Business rule to map MRVS to table fields but not working
the MRVS log is showing error like below
var value = current.variables.items_list; //  MRVS variable name here
	gs.log('Inside :', value);
var parser = JSON.parse(value);
gs.log(parser);
var addtable = new GlideRecord('x_pl4_move4u_item');
for(var i=0;i<parser.length;i++){
addtable.name = parser[i].name;
addtable.move_request = parser[i].move_request;
addtable.is_fragile = parser[i].is_fragile;
addtable.category = parser[i].category;
addtable.short_description = parser[i].short_description;
addtable.volume = parser[i].volume;
addtable.insert();
})(current, previous);
are you using correct variable name within mrvs here?
var parserList = JSON.parse(producer.items_list);
current.name = parserList[0].name;
current.move_request = parserList[0].move_request;
current.is_fragile = parserList[0].is_fragile;
current.category = parserList[0].category;
current.short_description = parserList[0].short_description;
current.volume = parserList[0].volume;
27 REPLIES 27
You dont have to glide in record producer script, there are two objects OOB : current and producer to update the record.
current.target_table_field_name = parser[0].name will work.
Ankur Bawiskar
I consider your business rule is after insert on the target table of record producer
it seems you are not using correct variable set name
HI ANkur,
My BR is in before insert not after and i used variavle set backend name.
please make BR as after insert.
Is your record producer target table different than x_pl4_move4u_item?
Nope. My record producer table and Br ara in same table x_pl4_move4u_item
