Fix for GlideappVariablePoolQuestionSet is not allowed in scoped applications
Kathy3
Giga Contributor
I am a total noob at JS, and I am working with code out of the article below to copy variables from RITM forms to the description field on the REQ form.
https://community.servicenow.com/community?id=community_question&sys_id=fa6fb6a9db58dbc01dcaf3231f961966&view_source=searchResult
I would like to know what my options are to alter the particular line so that it will work in our instance. We are on Kingston. I included the rest of the code below. TIA!
var gr= new GlideRecord("sc_req_item");
  gr.addQuery('request',current.sys_id);
  var varArr='';
  while(gr.next()){
  var set = new GlideappVariablePoolQuestionSet();
  set.setRequestID(gr.sys_id);
  set.load();
  var vs = set.getFlatQuestions();
  for (var i=0; i < vs.size(); i++) {
  if(vs.get(i).getLabel() != '') {
  varArr+=vs.get(i).getLabel() + " = " + vs.get(i).getDisplayValue()+'\n';
  current.description=varArr;
Jace Benson
Please use the editor so your code looks like this
find_real_file.png Also regarding your question, I'd write your own;
https://blog.jace.pro/post/2018-02-15-print-out-variables/
Kathy3
Giga Contributor
Thanks, I will try that out. I did notice when I was creating the rule, that it was on the ITSM spoke and not Global. O think that is where the conflict is.
