Flow designer catalog task assignment group not populating
satya30
Hi, I have  Catalog item once this is request flow gets triggered and after the approval catalog task is created.
In Dev environment everything is working fine. When coming to the UAT: Flow is getting executing and the flow context i could d see that the assignment group is the having the values but on the catalog task assignment group value is not setting. Please help me with this.
Below I attached the screenshot of flow execution and the catalog task created.
Thank you.
Thank you.
Flow execution in UAT:
Flow execution in DEV:
Step Screenshot:
@satya30
you are hard-coding that group.
Is that group present in UAT? If not then it won't set the group.
If not present then import from DEV and load in UAT.
yes, it is available beacuse it is working for other catalog items
@satya30
any business rule or other script is clearing that group from SC Task?
Did you check XML of that catalog task if value is there but on form some script or UI policy is clearing it out?
@satya30
Hope you are doing good.
