Flow designer email body
05-04-2022 06:19 AM
Hello Experts,
I am trying to bring variables value to email body using flow designer. Below is the thing that I have designed. Email is getting triggered but the variables value are not getting populated on the email body.
How to achieve this?
Shoheb
05-04-2022 08:09 AM
I am getting blank value in the notification result.
05-04-2022 11:43 AM
Do those variables as part of this test actually have a value filled in for them?
05-04-2022 06:24 AM
Are you doing lookup on Application Model table? if yes then it should be visible.
Also make sure respective application model have all those value prefilled when you are testing.
05-04-2022 06:51 AM
Hey,
When you are trying to display a reference field, dot walk to the display name as name or number.
Aman Kumar
05-04-2022 09:15 AM
Did you try this?
Aman Kumar
