‎06-17-2021 01:48 AM
I'm currently configuring a Flow Designer for onboardning new employees, and the purpose of this Flow is to look up groups which are standard groups for a specific role on sys_user_group. The Flow shall then put the new employee (user) into each groups that are, for example, tag'ed with 'Main role'.
However, in action 'For Each Item XXXX' I get the error ''Value of field record is not a GlideRecord''. Here's the context;
Operation(1a2a4aa5db3470107438de0cd3961988.ae2a4aa5db3470107438de0cd39619b5.9d7227a473210300e4fd234ffff6a72e) failed with error: com.snc.process_flow.exception.OpException: Value of field record is not a GlideRecord
at com.snc.process_flow.operation.FieldValue.getGlideRecord(FieldValue.java:145)
at com.snc.process_flow.operation.CRUDOperation.getInputValidGlideRecord(CRUDOperation.java:52)
at com.snc.process_flow.operation.RecordUpdateOperation.run(RecordUpdateOperation.java:23)
at com.snc.process_flow.engine.Operation.execute(Operation.java:165)
at com.snc.process_flow.engine.ProcessEngine.executeOps(ProcessEngine.java:498)
at com.snc.process_flow.engine.ProcessEngine.run(ProcessEngine.java:414)
at com.snc.process_flow.engine.ProcessEngine.callBlock(ProcessEngine.java:213)
at com.snc.process_flow.engine.CallBlockOperation.callBlock(CallBlockOperation.java:79)
at com.snc.process_flow.engine.CallBlockOperation.run(CallBlockOperation.java:60)
at com.snc.process_flow.engine.ProcessAutomation.run(ProcessAutomation.java:66)
at com.snc.process_flow.engine.GlideProcessAutomation.runSync(GlideProcessAutomation.java:158)
at com.snc.process_flow.engine.GlideProcessAutomation.runWithDomain(GlideProcessAutomation.java:261)
at com.snc.process_flow.engine.GlideProcessAutomation.lambda$runAsUserSync$1(GlideProcessAutomation.java:239)
at com.snc.process_flow.engine.PFSessionClone.run(PFSessionClone.java:58)
at com.snc.process_flow.engine.GlidePFSession.runPlanAsUserSession(GlidePFSession.java:42)
at com.snc.process_flow.engine.GlideProcessAutomation.runAsUserSync(GlideProcessAutomation.java:237)
at com.snc.process_flow.engine.GlideProcessAutomation.messageFlow(GlideProcessAutomation.java:292)
at com.snc.process_flow.engine.GlideProcessAutomation._start(GlideProcessAutomation.java:456)
at com.snc.process_flow.engine.GlideProcessAutomation.access$500(GlideProcessAutomation.java:106)
at com.snc.process_flow.engine.GlideProcessAutomation$StartBuilder.start(GlideProcessAutomation.java:1122)
at com.glide.flow_trigger.engine.TestButtonTriggerRunner.run(TestButtonTriggerRunner.java:220)
at com.glide.flow_trigger.engine.TestButtonTriggerRunner.test(TestButtonTriggerRunner.java:224)
at com.glide.flow.providers.FlowGlideProvider.testFlow(FlowGlideProvider.java:1161)
at com.glide.flow_design.rest.FlowService.testRunFlow(FlowService.java:601)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at com.glide.rest.handler.impl.ServiceHandlerImpl.invokeService(ServiceHandlerImpl.java:44)
at com.glide.rest.processors.RESTAPIProcessor.process(RESTAPIProcessor.java:287)
at com.glide.processors.AProcessor.runProcessor(AProcessor.java:596)
at com.glide.processors.AProcessor.processTransaction(AProcessor.java:266)
at com.glide.processors.ProcessorRegistry.process0(ProcessorRegistry.java:181)
at com.glide.processors.ProcessorRegistry.process(ProcessorRegistry.java:169)
at com.glide.ui.GlideServletTransaction.process(GlideServletTransaction.java:44)
at com.glide.sys.Transaction.run(Transaction.java:2275)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at java.lang.Thread.run(Thread.java:748)
Any idea of what it is?
Best regards,
Adrian H.
‎06-17-2021 02:31 AM
As you can see you did not select any task in the task field of Add Worknotes action. So the system is searching of that and it is not able to find the record you want to update worknote on.
Solution to this is to either remove the Add Worknote action from the flow or select the correct task in the task field.
‎06-17-2021 02:27 AM
‎06-17-2021 02:29 AM
‎06-17-2021 02:35 AM
you did not add the task record in the data pill here
