Flow designer scripted approvals not working
Priya75
I am creating a flow for a table(x_nose_ap_infringemnet) , so i have kept the trigger point :-when the approval field is changed to Approval after this i am sending the record sys_id to action which is taking input as sys_id and it is calling a script include from there and sending back the approval group sys_id..it could be multiple or single.
Action (called after trigger)
var record=inputs.a2precord; //sys_id from flow
var group = [];
var getApp = new Infg_AprrovalMatrix();
group = getApp.getApprovals(record);
output.approvalList="ApprovesRejectsAnyG["+group+"]" //also getting the sys_id from the script include
the Approval is generated but the approval doesn't wait for approval or rejection . the Ask for approval output shows :- state as skipped. how can i make it wait for it? WhatsApp Image 2025-12-02 at 19.30.41.jpeg
9 REPLIES 9
Jennifer Metz
Hello @Priya75,
It's hard for me to assess the issue without seeing any logs or records. The ask for approval action waits before moving forward. It sounds like it is skipping because there were no approvers. I would check the logs to see what approvers were returned. If you are unable to see in the logs, then create some log messages in your script include and see what is being return.
Hope this helps!
@Priya75 The flow logs clearly indicate the warning 'Skipped due to no valid approvers'. I recommend you to check your users in the group again. Also, please check the output of the line
group = getApp.getApprovals(record); and see if this returns a valid group sys_id.
Hi ,
users were active, i have changes the way it returns the output .it worked i return this from script include "ApprovesRejectsAnyG["+group+"]" and it is now generating the approval but i have another problem this gives output as approval status=approved if the approval is approved after that i have used "IF" which is evaluating to true but after that if i use Update record , it is giving me error.
