Flow designer send Email
LT_23
Hello I have the follwoing flow and I want to include an email that will be sent to the manager so that they know when their employees open a request.My question is where should I add this action and should I use the Send Email over the notification or else.
Thank you in advance
2 ACCEPTED SOLUTIONS
Aditya_hublikar
Hello @LT_23 ,
You can use Send email action which is more relative for you requirnment . If you use send Notification action then you need to create email notification first and then you can use that notification in send notification action . You can use send email action at starting of flow action if you want to simply send details about when their employees open that request .
If this helps you then mark it as helpful and accept as solution.
Aditya
Hello @LT_23 ,
I hope you are doing well . Does my response helps you ? If yes then mark it as helpful and accept as solution it will helps future queries.
Aditya
@LT_23
As per community feature you can mark multiple responses as correct.
💡 If my response helped, please mark it as correct ✅ as well so that this helps future readers find the solution faster! 🙏
SohamTipnis
Hi @LT_23,
You can use Send Email, which is available in Actions. This specific action is used to send email notifications based on your triggering conditions or process of flow.
If you find my answer useful, please mark it as Helpful and Correct 😊
Soham Tipnis
ServiceNow Developer ||  Technical Consultant
LinkedIn: www.linkedin.com/in/sohamtipnis10
yashkamde
Hello @LT_23 ,
As per your requirement you want to send email as soon as the employee open request so there is no condition to monitor the request opening so after the 3rd step i.e Wait for catalog task condition -
You can add send Email action which is present OOTB in flow designer..
When the employee open the request and update the state or any fields in the request record..
If my response helped mark as helpful and accept the solution
WataruS
Hi @LT_23
You can send emails by using the Send Email action (OOTB Function).
This can be achieved by inserting this action after the request record status is set to Open.
Tejas Adhalrao
Hi @LT_23  ,
 hi 1) make sure that you flow is deactivated / click on edit flow
2) hover the gray line and select the + icon where you have to add the send email action
 or
2) click on the + icon  , and select the action and search send mail and  select send mail
3)select values for the action
4) this option help you to set  dynamic values
at the last save and activate your flow and test
