Flow designer to check catalog item priority condition?
sukran
We have a requirement in flow designer after RITM closed .it should check all child catalog task priority.
If all are low then make RITM field compliance checked true.   If any one of the catalog task is not low ( medium , high. critical) then compliance field as false
How to do in flow designer?
SAI VENKATESH
Hi @sukran
You can follow the below steps as mentioned in the image:
Thanks and Regards
Sai Venkatesh
Hi @SAI VENKATESH it weird . After adding end flow to flow designer it seems working fine
Previsouly Even though if condition satisfield as false but update record action executed( weird)
seems bug in flow designer
after adding end flow to the flow execution , its works
Hi @sukran
If the issue resolves and could you please mark as solution
