Flow designer update trigger conditions
04-09-2026 08:17 PM
Hello Team,
I have one outbound integration setup with one third-party tool.
Once a incident is created(and assignment group is x) the incident needs to be created on the third-party system .I have created a flow and got the response and did set the number into correlation id field successfully.
Now i want update as well if my incident gets updated then which value got updated accordingly dynamically i need to build the payload.(Also integration for this not trigger for all the fields update only some fields like state additional comments etc.)
Now if i created a update flow one new then what conditions i should keep so that it wont go on loop and also i need to find which field/fields got updated if they need to be updated in the third party system then only i will trigger the integration otherwise not.
Also if both of these can be done in one flow or two flows needed i need help on the conditions of the flow what i should put so it won't go on loop and it should do the job as needed.
@Ankur Bawiskar any suggestions?
04-09-2026 08:35 PM
So you make API call, you update the INC with correlation ID and you want to trigger flow when Correlation ID is updated?
I didn't get the clear picture
04-09-2026 08:43 PM - edited 04-09-2026 08:57 PM
No @Ankur Bawiskar
There are two scenarios incident create integration should call also if incident updates(some fields) only integration call should happen and update the record.
Now one flow i have done for creation and in the response i am bringing the id and setting it in the corelation id successfully.
Now i want to build a flow for update i created a flow and condition as (additional comments changes or state changes etc) which is fine i want to know now which all fields got changed so that accordingly i will build the payload.
Also i have the question can both of these flows can be clubbed into one as we have a record trigger condition as created or updated?
so basically i have two questions how i can get the changed fields which all got updated accordingly i have to create the update payload .
and the second question is if i can club both of these to create or update what all conditions need to be made so it will work fine or it's better to keep separate only?
04-09-2026 09:13 PM
better to separate out
1 flow for INC create and make API call and update Correlation ID
1 other flow when Record gets updated and make another API call
04-09-2026 09:19 PM
Yes @Ankur Bawiskar ,
Fine with one more flow when updated and trigger condition when additional comment changes or state changes or other required fields in the trigger.
Now i want to get on time like what all fields got updated to create the payload dynamically
04-09-2026 10:00 PM
Hello @Ankur Bawiskar ,
the below are the fields when i have to trigger the update actually
state -
on hold reason
impact
urgency
Additional comments
resolution note
resolution code
resolved_at
