Flow Designer - Wait for Condition - Catalog Variable
kklosterman
Has anyone figured out a way to do a Wait for Condition in Flow Designer on a Catalog Item Variable Value ?
Example
9 REPLIES 9
Adam Peterson
Wondering the same thing! Were you able to figure it out?
Not yet ...
Harsha Pappala
On table sc_req_item, click on show related variables. Find variables field, then select the item you want to use and the variable from there.
Looks like something below
Parnu K_
Use encoded query to do it.
Please mask as answer if this work for you.
