03-10-2017 02:39 PM
As each time a user selects a different homepage while on the homepage, they are effectively customizing their user preference so that the next time they come to the homepage, it displays whatever homepage they left it on.
This create a problem for us as not all users know how to get back to the Self Service homepage - therefore, I want to force a default (a real default, not a customized default) homepage to load at login - specifically the Self Service homepage. I don't see a configuration to do this (which seems like an obvious gap to me, so I am wondering what I'm missing)...and I can't seem to find anything that addresses this need.
What options are available to configure this? And if none, I'm open to suggestions about the best way to force a system default homepage at login.
Thank you,
Robert
Incident Management
03-10-2017 02:53 PM
Hi Robert, you should be able to use the solution I described in this thread. It's basically just a business rule that watches for users to change their homepage preference, then it resets it. This kind of change takes effect when the session is started, so your users could switch homepages at will, and then when they log in again, they're back to the homepage you want them to see.
Re: how set default homepage for select users depends upon rules
06-19-2018 12:52 AM
I know this thread seems to be very old. But I have the same requirement but without logout and login again , is there any other way to select one of the pa_dashboard to be displayed by default when the user starts the session without login.
