Glide Record is not working in Business Rule
kapilscs
Below is my business rule which is trying to fetch Assignee Group role however it is not working, grRole.getDisplayValue('role') is not fetching any value.
  //var temVar = new HelloWorldSN();
  //var assinGrp = temVar.func2();
  var assigneeGroup = current.getDisplayValue('assignment_group');
  gs.log("assigneeGroup" + assigneeGroup);
  var grRole = new GlideRecord('sys_group_has_role');
  grRole.addQuery('group',assigneeGroup);
  grRole.query();
  var temRoel = grRole.getDisplayValue('role');
  gs.log("temRoel "+ temRoel);
                              if(grRole.next()){
current.setValue('x_95063_servicenow_assigneegrouprole',"itsm");
  current.update();
})(current, previous);
Kapil Shinde
Pradeep Sharma
Hello Kapil,
Create a BEFORE business rule with the below modified script. Don't use current.update(); in before business rule to avoid performance issues.
  grRole.addQuery('group.name',assigneeGroup);
  grRole.query();
  if(grRole.next())
Reference:
http://wiki.servicenow.com/index.php?title=GlideRecord
13 REPLIES 13
Hi Pradeep,
below code works fine when used in a script include however not sure why it is not working when used in after business rule.
var HelloWorldSN = Class.create();
HelloWorldSN.prototype = Object.extendsObject(global.AbstractAjaxProcessor, {
  helloWorld: function() {
  var gr1 = new GlideRecord('sys_group_has_role');
  gr1.addQuery('group', this.getParameter('sysparm_groupName'));
  gr1.query();
                              if(gr1.next())
  return gr1.getDisplayValue('role');
  //return "Hello " + this.getParameter('sysparm_user_name') + "!";
      type: 'HelloWorldSN'
Thanks for the update Kapil. The Same code will not work in BR as both have different syntax. You will have to adjust your code.
Did you try with the code I have shared above?
Thank you Pradeep,
your code is working however current.setValue('x_95063_servicenow_assigneegrouprole',"itsm"); is not setting value without current.update();
Is this on your personal dev instance?
Yes Pradeep...
