GlideRecord issue using addNotNullQuery
ServiceNow Use6
I am working on GlideRecord method addNotNullQuery() and I am facing the issue. I believe I am getting wrong output. Kindly help.
var gr = new GlideRecord("incident");
var shortDesc = gr.addNotNullQuery('short_description');
while(gr.next()){
gs.addInfoMessage("The short description for " + gr.number + " is " + shortDesc);
Suman P.
Srikanth_Peru
Hi @ServiceNow User
Please use this Script :
gr.addNotNullQuery("short_description");
while(gr.next()){
gs.addInfoMessage("The Short Desription for: " +gr.number +" is "+gr.short_description);
Please mark my response Answered and Hit Helpful
Srikanth_Peru
Hi @ServiceNow User
while(gr.next()){
Hemant Goldar
addNotNullQuery()- a filter that specifies records where the value of the field passed in the parameter is not null.
You may find the below link helpful.
https://developer.servicenow.com/dev.do#!/reference/api/orlando/server/no-namespace/c_GlideRecordSco...
while(gr.next()){
gs.addInfoMessage("The short description for " + gr.number + " is " + gr.short_description);
Hemant
Ankur Bawiskar
your script should be like this
while(gr.next()){
