Help in adding link in field message
Pihu1
Hi Community,
Need help in adding a link in field message ?when user clicks on it, it should point to new window.
Pihu
11 REPLIES 11
Field messages don't support HTML, you can do it on form info message if that works for you
Something like
g_form.addInfoMessage("Please <a href = '/incident_list.do' target='_blank'>Click</a>");
Thanks Anurag it worked by using addInfoMessage.
But can we do it from the below link.
https://community.servicenow.com/community?id=community_question&sys_id=c76c47a5db9cdbc01dcaf3231f961934
Pihu
That is an unaswered Question , and if you see Mile Allen's reply there. he also said the same.
You using it in business then it should be gs.addInfoMessage() & not g_form.showFieldMessage()
So, last line becomes
gs.addInfoMessage(message);
No ,I am not using in BR I have used in client script
