Help with filter: Updated by != member of Assignment Group
JP-ODU
I'm having a hard time with what I expected to be a straightforward filter: the request is to list only those Incidents that have been last updated by a user who is not a member of the incident's assignment group.
The first part is easy: Updated by | is not
The challenge I'm having a hard time wrapping my head around is how to correctly express the "member of the incident assignment group" in the filter. Any ideas?
Thanks!
11 REPLIES 11
asifnoor
I think you can try like this.
updated_by is NOT and then mention something like this in the text field
javascript:gs.getUser().isMemberOf(" Application Development");
Mark the comment as a correct answer and helpful if this helps.
Ankur Bawiskar
So basically you want to show incident to User A if he/she is the updated by user for the ticket and when he/she is not member of that group assigned to incident?
what if the user has updated by as his/her name but a member of all the incidents? what to show? -> do you want to show blank incident table i.e. return no records
I have assumed this in below script that return no records when he/she is member of group
use below query in query business rule;
var isMember = gs.getUser().isMemberOf(current.assignment_group);
var encodedQuery = 'sys_updated_by=' + gs.getUserName();
if(!isMember){
current.addEncodedQuery(encodedQuery);
else{
// return no records
var sys_id = -1;
current.addQuery('sys_id',sys_id);
Uzzawal Agrawa1
Giga Contributor
Did you get any solution for this query, please help with the query I have similar requirement
Hi
To address a second requirement, I would suggest creating a new Dynamic Filter (System Definition > Dynamic Filter Options) with a referenced client-callable script (Script Include) which provides a list of users that are not members of the specified group.
You may check an example here
Hope it helps
