Help with removing values from array
sndev1099
Giga Expert
Hi, I need some help with setting a field from an array. My below business rule runs on an m2m table and updates the OIM entitlements field when any values are added to the related list table. However, I need some script for the if current.operation() == delete part. Can anyone help?
Here is an example, I have added 6 entitlements and it's updated the OIM entitlements field with the sys_id's. However, if they are removed, I need to update OIM entitlements field with new values (possibly push new values to an array?)
    var m2moim = new GlideRecord('x_lbg_insider_risk_insider_access_lookup');
    m2moim.addQuery('sys_id', current.ir_access_categorisation);
    m2moim.query();
    if (current.operation() == 'insert') {
        while (m2moim.next()) {
            var entList = [];
            var m2Gr = new GlideRecord('x_lbg_insider_risk_m2m_catalog_acce_ir_access_ca');
            m2Gr.addQuery('ir_access_categorisation.sys_id', m2moim.sys_id);
            m2Gr.query();
        while (m2Gr.next()) {
            entList.push(m2Gr.getValue('sys_id'));
            m2moim.u_oim_entitlements = entList.join(',');
            m2moim.updateMultiple();
    } else if (current.operation() == 'delete') {
})(current, previous);
Baala T
Mega Guru
I just modified the code, just give a try,
    m2moim.query();
		var entList = [];
            m2Gr.query();
		var entList1 = [];
            var m2Gr1 = new GlideRecord('x_lbg_insider_risk_m2m_catalog_acce_ir_access_ca');
            m2Gr1.addQuery('ir_access_categorisation.sys_id', m2moim.sys_id);
            m2Gr1.query();
			while (m2Gr1.next()) {
				entList1.push(m2Gr1.getValue('sys_id'));
            m2moim.u_oim_entitlements = entList1.join(',');
Bala T
Ankur Bawiskar
@bracken91
Seems duplicate post.
Your previous question below where approach has been mentioned from my side.
https://community.servicenow.com/community?id=community_question&sys_id=e15c541c1ba69090d2ccea89bd4b...
Hi Ankur. For some reason I couldn't respond to the post.
Your script didn't work for me unfortunately. This is my current script, which works apart from it doesn't fully clear the list. Always leaves one sys_id.
    m2moim.query();
            var entList = [];
            m2Gr.query();
            var entList1 = [];
            m2Gr1.query();
Baala T
Mega Guru
    m2moim.query();
		var entList = [];
            m2Gr.query();
		var entList1 = [];
            m2Gr1.query();
Bala T
