‎08-11-2022 05:49 AM
‎08-11-2022 06:14 AM
Then do mapping from Variable set list then like below see it should work in my opinion, by default it will copy for all RPs in my opinion, Please try.
Lastly you can create before BR as well on target table and copy field like below
current.watch_list = current.variables.watch_list
But first try with Variable list method that should work I guess.
‎08-11-2022 07:11 AM
‎08-11-2022 07:28 AM
you have not checked 'Insert' or 'Update' checkbox, can you please check only 'Insert' checkbox and try creating new record producer request again ?
‎08-11-2022 08:31 AM
Thank You Very Much
‎08-11-2022 08:36 AM
In the future, please give as much information as you can so that replies your question are more relevant.
This entire thing could have been resolved by simply naming the variable the same name as the field name on the produced record.
Example: if you create a variable on record producer called: caller_id and after submission of the record producer, an incident is created AND there's a field called: caller_id on it...then automatically the field is mapped to that incident field.
You wouldn't need script or business rule, etc. So if you're able to do that and name it the same name, then that's a recommended way to handle all this.
Please keep that in mind for the future.
