How can you disable a maintenance or blackout window
imran rasheed
Is there a way to make in active a maintenance window or blackout time frame when applied to the Change Request module.   Most all other areas of ServiceNow give you the ability to make something "inactive".
VigneshMC
You can update the repeat until field to some date in past ,in schedule entry record to make it inactive.
I don't want to delete as I need to keep for historical reference.   Need a deactivate option.
I have a similar request to de-activate a Maintenance Schedule without loosing historic data, did you find a way? Regards, Winnie.
