How do I delete a on-call schedule?
clarkchong
Is there a way to remove/delete an on-call schedule that I have setup? It seems there is no option to do that
Hi Clark,
You can disable the rota. In Jakarta, I went to the calendar, right clicked on the rota and chose the Action Edit Rota.
The resulting popup has an Active check flag.
To do this, you'll need one of the following roles (not sure which without further digging), roster_admin, rota_admin, rota_manager
11 REPLIES 11
Here is a breakdown of the roles and how to delegate them:
https://docs.servicenow.com/bundle/geneva-servicenow-platform/page/administer/user_administration/re...
A user with the rota_manager role can edit the rota's active flag for his/her groups.
Hi Clark,
If I have answered your question, please mark my response as correct so that others with the same question in the future can find it quickly and that it gets removed from the Unanswered list.
If you are viewing this from the community inbox you will not see the correct answer button.   If so, please review How to Mark Answers Correct From Inbox View.
Thank you
