How do I read the values of variables in multi row variable set ?
Meghana11
I have create a multi row variable set for catalog item form in Service portal.find_real_file.png
So that I can add multiple disk spaces just by clicking on add.
How do I read the values of those variables in workflow?
I have tried using "current.variable_pool.disk_space.getDisplayValue()" and also current.variables.disk_space.getDisplayValue().
But I am not able to read the values of variables in variable set.
Please help me on this.
Meghana P
21 REPLIES 21
I will do a small test to simulate. One moment 🙂
Kind regards,
Mark Roethof
10x ServiceNow MVP
LinkedIn
Thanks Mark:)
I'm instantly getting below in logging:
Only tested with a Run Script step in the workflow containing:
gs.info(current.variables.disk_space);
(I named my MRVS "disk_space")
Kind regards,
Mark
LinkedIn
Community article list
Kind regards,
Mark Roethof
10x ServiceNow MVP
LinkedIn
Can you share your exact Run Script utility script? And what is the internal_name of your Multi-Row Variable Set?
Kind regards,
Mark
LinkedIn
Kind regards,
Mark Roethof
10x ServiceNow MVP
LinkedIn
Name of MRVS is extra_volume
Run utility script
var mrvs =current.variables.extra_volume.getDisplayValue()
gs.addInfoMessage(mrvs);
After submitting the catalog item and on workflow kickoff..when the script runs
