How do I read the values of variables in multi row variable set ?
Meghana11
I have create a multi row variable set for catalog item form in Service portal.find_real_file.png
So that I can add multiple disk spaces just by clicking on add.
How do I read the values of those variables in workflow?
I have tried using "current.variable_pool.disk_space.getDisplayValue()" and also current.variables.disk_space.getDisplayValue().
But I am not able to read the values of variables in variable set.
Please help me on this.
Meghana P
21 REPLIES 21
Ah oke.
At least this is wrong:
var mrvs =current.variables.extra_volume.getDisplayValue()
The .getDisplayValue() will cause the undefined. Also see my example, I didn't use the getDisplayValue().
Kind regards,
Mark
LinkedIn
Community article list
Kind regards,
Mark Roethof
10x ServiceNow MVP
LinkedIn
run script
displayed value
Not sure if this could be caused by the gs.addInfoMessage(). If you use gs.info(), is it then displayed correctly in your System Log?
Also double check if the internal_name of your Multi-Row Variable Set is exactly "extra_volume".
Kind regards,
Mark
LinkedIn
Kind regards,
Mark Roethof
10x ServiceNow MVP
LinkedIn
vinitha3
This is how you can get the variables inside MRVS.
//Script Include
var GetSODMRVS = Class.create();
GetSODMRVS.prototype = Object.extendsObject(AbstractAjaxProcessor, {
asset : function() {
var mrvs;
var arrayOfObjs = [];
var ritm_number = this.getParameter('sysparm_ritm_id');
var itemID = '70506da8db002300e69dfbef2996194a';
var ritmGR = new GlideRecord('sc_req_item');
if (ritmGR.get(ritm_number)) {
mrvs = ritmGR.variables.asset_details; //MRVS Variable name
var rowCount = mrvs.getRowCount();
for (var i = 0; i < rowCount; i++) {
var row = mrvs.getRow(i);
arrayOfObjs.push({
ip_address: row.ip_address,
host_name: row.host_name,
sid: row.host_name,
device_id: row.device_id,
mac_address: row.mac_address
return JSON.stringify(arrayOfObjs);
type: 'GetSODMRVS'
Then call this acript include in your run script block and access it.
Vinitha.K
Thanks for the response..
The values returns to be "undefined".
How do I handle that ?
Meghana P
