How to add a comment/work_note using script on Service Portal
JC S_
Mega Guru
We are trying to put a button on ticket form of Service Portal that once clicked will add an additional comment or a work note to the current incident being viewed.
We tried the following code on our if statement when the button is clicked but nothing is being added on the incident:
gr.setValue('work_notes', "The caller did not feel that this issue was resolved.");
gr.setValue('comments', "Please reopen this incident.");
gr.setValue('state', 2);
However the code on line 3 is working just fine (this if statement is inside another if statement which checks if the current table is the incident table).
Ujjawal Vishnoi
Hi Jimboy,
You can replace the code with either of the below blocks.
gr.work_notes="The caller did not feel that this issue was resolved.";
gr.comments= "Please reopen this incident.";
gr['work_notes'].setJournalEntry("The caller did not feel that this issue was resolved.");
gr['comments'].setJournalEntry("Please reopen this incident.");
Both will work.
Hope this helps.
Ujjawal
Jaspal Singh
Mega Patron
Hi Jimboy,
Try using below code,
gr.comments.setJournalEntry('Please reopen this incident.');
Jaspal Singh
Hit Like or Correct on the impact of response.
Its works \o/
anurag92
Set Value won't work in this case.
You can use:
gr.comments = "Please reopen this incident.";
Ujjawal Vishnoi
Hi Jimboy,
Both will work.
Hope this helps.
Ujjawal
