How to add a comment/work_note using script on Service Portal
JC S_
Mega Guru
We are trying to put a button on ticket form of Service Portal that once clicked will add an additional comment or a work note to the current incident being viewed.
We tried the following code on our if statement when the button is clicked but nothing is being added on the incident:
gr.setValue('work_notes', "The caller did not feel that this issue was resolved.");
gr.setValue('comments', "Please reopen this incident.");
gr.setValue('state', 2);
However the code on line 3 is working just fine (this if statement is inside another if statement which checks if the current table is the incident table).
Ujjawal Vishnoi
Hi Jimboy,
You can replace the code with either of the below blocks.
gr.work_notes="The caller did not feel that this issue was resolved.";
gr.comments= "Please reopen this incident.";
gr['work_notes'].setJournalEntry("The caller did not feel that this issue was resolved.");
gr['comments'].setJournalEntry("Please reopen this incident.");
Both will work.
Hope this helps.
Ujjawal
Thanks. Though the second option you mentioned can be more short by using what jaspalsinghchot mentioned above:
gr.comments.setJournalEntry('Please reopen this incident.');
I tried with below piece of code but its still not reflecting in incident..only the sys_journal_field is updated..
var gr=new GlideRecord('incident');
gr.setWorkflow(false);
if(gr.get('05b10fd9db9c3300b75573278c9619b8'))
gr.update();
Joe72
setWorkflow(false) prevents journal fields from being updated sadly.
