how to add approval states other than approve or reject in workflow????
suprakash
Giga Expert
I have added a state in sysapproval_approver named review
I have attached an image in which you can see that I have added a state named review in the aproval activity.   when i am changing state in approval table to Approved or rejected the flow is going fine in the workflow. But the problem is when i am changing the state to review the flow is not working .
I given the condition in the workflow activity for state review activity.result == 'reject-review'
'reject-review' is the value of the state   review that I added in approval table
11 REPLIES 11
Question related to your statement. I have created an extra condition called "rework". Once an approval is flagged as rework, I would like for the workflow to generate a new set of the same approvals. The workflow currently circles back to the same group approval if it meets this condition.  I would like for one record to be marked as rework and the others no longer required similar to rejected approvals.
The issue I encountering now is that only the rejected record is marked as rework but the previous requested approvals are not marked as no longer required.  How can I apply the same logic of rejected approvals to a new condition.
Thanks in advance.
Ernie C
Hi Jake,
Is there anything else that's required to get this to work?  I've completed both of these steps but when the new approval state is selected the 'Approval - User' Activity is not processing the result and just remains with a state of 'Running'
Robin
Robin,
We need to add a business rule in sys_approval table to trigger the workflow.
I assume that the Business Rule 'Nudges' the Requested Item Workflow then the sys_approval record is updated?
Robin
Bosco Sahayaraj
Giga Contributor
Team, I am facing this same issue. Can some one help me with the new links.
